Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Overview:
This VI will save all your VI's control values to a file by converting them to an XML string.
Description:
The VI will also load these values into the VI's controls.
Requirements:
Steps to Implement or Execute Code:
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**"
Very nice. Didn't know this was possible, this code will surely help me with a project I have.
really thank you
I just tested the VI but I notice that it doesn't work ;( It goes bad when the loaded xml string needs to be flattend by the "xml flatten vi" it says
Error 1106 occured at Unflatten From XML in Save or Read Control Values To and From a file.vi
Possible reason(s): LabVIEW: The XML tag describing the type of data does not match the wired type.
You know a solution?
Looks like there is a bug in LabVIEW 2009 that does not allow Variants to faletten to XML. I modified the code to make it work. Try the new download. Not as clean, but does the trick.
Pity... because the xml was pretty readable now it isn't anymore because you don't know what value the data represents.
Good Idea but I had to change the scheme slightly to get it to work in 8.6.1.
Late to the party, but this helps a lot, thanks!
