Example Code
Save for Previous Version and Update Re-entrant Property
Code and Documents
Overview
Demonstrate the use of Invoke node to save labview VIs to previous version and update re-entrant property
Description
This VI allows the user to quicky convert a single VI or a whole folder full of VIs to a previous version to provide compatibility. The front panel allows the user to specify the destination folder and Labview version. Also it is able to change VIs re-entrant property at another tab at the front panel. This program has the capability to change further properties of VIs.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download and unzipthe attached folder to your computer
  2. Open the VI "Save for Previous.vi"
  3. Run the program
VI Block Diagram of "Save for Previous.vi"
Aaron. E
Product Performance Engineer
Dyson
Comments
Terry_ALE
Active Participant Active Participant
on
Does not convert lvproj and lvlib files, could be a good enhancement.
ALE Consultants
