Example Code
Row and Column Averages for a 2D Array using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how you can calculate row and column averages for a 2D array.
Description
This demonstrates basic array manipulation and math used to calculate averages.
Requirements
  • LabVIEW 2012 (or compatible)
1. Run VI
2. Use Enum control to change color
VI Block Diagram
 Row Column and Totale Averages for 2D array LV2012 NI verified.pngRow Column and Totale Averages for 2D array LV2012 NI verified.png
Comments
agarwal_ravindr
on
Thank you for posting code. Its really helpful.
LvL1995
on
Why does it use for loops?
@HunterSeeker wrote:
Overview
Description
Requirements
LabVIEW 2009 (or compatible)
This VI is probably more useful as a subVI but it can be used stand-alone.
