Example Code
Register VISA Event as Top Level Event Using a User Event Structure
Products and Environment
    Software
  • LabVIEW
    Driver
  • NI VISA
Code and Documents
Overview
The following example demonstrates a method for translating VISA event handling to a top-level user event structure.
Description
This program demonstrates a method for translating VISA event handling to a top-level user event structure. Using application control methods, VISA events may be extracted and registered at the user level; such that, program execution may be triggered by events within VISA hardware on the system.
Requirements
  1. LabVIEW 2012 or later
  2. NI-VISA Driver
  1. Configure the Serial Port
  2. Enable the VISA Event of your choice.
  3. Create a User Event to associate the VISA event with.
  4. Register for the User Event, when it is fired.
  5. Use a User Event Structure to handle dynamically generated User Defined Events.
  6. Wait for the VISA Event to occur.
  7. Assign the VISA event status, to a Generated User Event
  8. The second event case monitors for the User Event, and will execute when it is fired.
  9. Close the VISA Resource.
VI Snippet
Patrick Corcoran
Application Engineering Specialist | Control
Comments
_Xilinx_
on
The "Service-Request"-event selected by default did not work for my ordinary COM-port!
"Serial character"-event Type does work!
denibel
on
Bad solution. The good one does not exist, because "Visa event" is not an "Event".
Ting1224
NI Employee (retired)
on
Hi denibel,
I agree with you. It seems that this example still utilizes polling instead of real event scenario.
Do you have any better solution for registering VISA event as a top level user event?
Steve_Block
on
To be more specific about the previous two poster's comments, I'm looking to not only register that the event occurred, but also have the data and timestamp included in the event buffer.
Rehal
on
I tried your posted example without success.
Can someone help me shed some light on the event structure and serial port combined function as as soon as i try to implement it it stops the serial data from being read.
This example works as old school, but
This event structure does not as I am just passing the data outside the event structure.  Would channel wire structure help?  Please advise.
