Example Code
Reed-Solomon Decoder
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This IP performs decoding on the Reed-Solomon encoded data packets.
Description
National Instruments has partnered with Prentice Hall to bring you large portions of in-depth technical topics from several PTR RF and Communications books, including Digital Communications: Fundamentals and Applications, 2nd Edition. This series of content is designed for a broad range of audiences, from experts who want to review a specific topic to students who need easy-to-understand documentation for their projects.
The IP specifications are as mentioned below.
  • Decodes Reed-Solomon code (255, 239) encoded bits.
    • Code word length(n)= 255 symbols
    • Data word length(k)=239 symbols
    • Parity length(2t)= 16 symbols
  • Supports shortened codes.
  • Symbol size= 8 bits
  • Error correcting capability= 8 symbols
  • Field generator polynomial p(x)= x8 + x4 + x3 + x2+ 1
  • Code generator polynomial g(x)= (x + a0)(x + a1)(x + a2)…(x + a15);a= 0x02
  • Fully synchronous design using a single clock, with speed optimization.
  • Maximum clock rate= 51MHz
  • The IP handles one symbol(8 bits) per clock cycle and requires a maximum of 850 clock cycles to process a block of n symbols
NOTE: The example requires Modulation toolkit to perform Reed-Solomon encoding on the PC.
Requirements
Software Requirements:
LabVIEW FPGA 2010
LabVIEW FPGA RF Communications Library 3.0 available on NI Labs
Hardware Requirements:
PXIe-5641R
Comments
keanu13
Member
Member
on
NI Labs can promote its Reed Solomon encoder decoder at various IP portals such as IPsupermarket.com, design-reuse or chipestimate
Member
Member
on
Can this code be modified to work for some other field generator polynomial?
