Overview
This example will read a .csv file and display it in an array indicator.
Description
This example shows how you can use the Read from Spreadsheet VI to pull data from a spreadsheet. In order to directly read Microsoft Excel files we need to use the Report Generation Toolkit (examples in Help»Find Examples), but in Excel you can save a spreadsheet as a Comma Separated Value file (CSV) and you can read that using the Read from Spreadsheet VI.
While this example will not necessarily work for all formats of spreadsheets, it demonstrates the usage of the delimiter and should be a good starting point to build an application.
To Write to a CSV Spreadsheet file check out this example: Getting Started: Write Continuous Data to Spreadsheet (CSV) with Headers
Requirements
LabVIEW 2012 (or compatible). Download contains versions for: LabVIEW 8.6, LabVIEW 2012
Description-Separate-2
Unzip the attached folder "Read From Spreadsheet_LV2012_NI Verified.zip" to your computer and Open the Read from Spreadsheet VI
Set the path to your csv file
Set the My File has Row Headers switch to on
Front Panel
Block Diagram
How-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
really helpful.
¿Where is MyData.csv?
thanks you
Create a dummy file with extension name .csv to evaluate this program
How do you get it to read both characters and numbers from all the rows. Each row has columns mixed with both characters and numbers and this just takes the number out to display besides the first row.
How to get an fft from csv file ? I have vibration sensor data in csv from excel file. The 1st column is time data, the 2nd column is the data itself. This is my email dilaekayati@gmail.com . I've tried many fft function , but none of them show the fft i really want.
here is the front panel result when i run the block diagram :
can you upload your version somewhere? thank you!
thank you for this helpfull exemple it's a very good explanation![]()
the sample code and instruction is easy to follow and can run on my 2020 NI, very helpful, thank you and please keep it up
