Example Code
Radio Buttons for Multiple Cases
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview: This VI takes 4 buttons on the front panel, and corresponds each to a different code.
Description: This VI takes 4 buttons on the front panel, and corresponds each to a different code. The code is not inserted into the example, but a blank case structure is in place of the desired code. The for loop at the beginning simply tells the user what case is currently active, and the case structure is selected inside the event structure.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the Vi.
2. Click on different Exp buttons.
3. Look at the String indicator.
4. Stop the VI.
Additional Information or References:
Chris Van Horn
Applications Engineer
Comments
HunterSeeker
Member Member
on
Can you please add some screenshots, or a snippet.
HomineAsacri
on
I'm started to learn Labview and this a difficult example for me but I was useful in my homework Thank You!!!!
