Overview: This VI takes 4 buttons on the front panel, and corresponds each to a different code.
Description: This VI takes 4 buttons on the front panel, and corresponds each to a different code. The code is not inserted into the example, but a blank case structure is in place of the desired code. The for loop at the beginning simply tells the user what case is currently active, and the case structure is selected inside the event structure.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the Vi.
2. Click on different Exp buttons.
3. Look at the String indicator.
4. Stop the VI.
Additional Information or References:
Can you please add some screenshots, or a snippet.
I'm started to learn Labview and this a difficult example for me but I was useful in my homework
Thank You!!!!
