Introduction
Have you ever wanted to clean up all of the wires in your VI without moving anything else? Now you can using VI Scripting and quick launch shortcuts:
How to Use
Additional Notes
For more information on creating quick launch shortcuts, refer to Darren's LabVIEW Artisan blog
That's pretty slick! How do I use multiple character hot key names with quick drop? For example if I want this code to be run with ctrl-rt, the ctrl-r is picked up and the vi is removed before the disired action run.
I just now saw this comment...there is no way to do a multiple ASCII key shortcut (like Ctrl-R-T) with Quick Drop. The best I can suggest is that a given shortcut can perform two different operations, depending on if the [Shift] key is pressed. For example, Ctrl-Space-Ctrl-D will create controls/indicators on all unwired terminals on the selected object(s), but Ctrl-Space-Ctrl-Shift-D will create constants on the inwired input terminals.
I tweaked this shortcut as I was saving it for LabVIEW 2011. I added it as "All Wire Cleanup.vi"
-Added Undo
-Added option to perform full block diagram cleanup if 'shift' is pressed. (and then cleaning up the wires like normal)
-Consolidated to a single VI and used the documentation to assign a default hotkey. I chose U because that is what is used for block diagram cleanup when quick drop is not open.
Ever accidentally fire off this shortcut and have to wait a minute for it to parse through the wires of a large diagram? I added a progress bar and abort button in the new version
All Wire Cleanup with Abort.vi
I added the ability to cleanup only the seleted wires (still cleanup all wires if nothing is selected) to the All Wire Cleanup with Abort.vi.
