Example Code
Programmatically Select ROI on Image by Clicking and Dragging Mouse
Code and Documents
Introduction
This VI shows you how to use the ROI tools of the Front Panel Image Control to create an ROI. Then you can programmatically take the coordinates from this ROI to process your image further.  In this example, the coordinates from the ROI are used to overlay a rectangle onto the original image.
Steps to Complete
Open the attached VI and follow the instructions on the front panel.
Additional Notes
This VI was written in LabVIEW 8.6 and using the Vision Development Module 8.6.
Hope this helps.
-Ben
WaterlooLabs
Comments
mrutm
on
There was no VI
DAKBIAS
Licínio
on
Hello Ben,
Thank you for this VI. It is usefull.
Licínio
Contributors
