Example Code
Programmatically Select DAQmx Physical Channels for Task Configuration
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example demonstrates a programmatic method for selecting available devices on a system for DAQmx task configuration.
Description
Employing methods to programmatically select available devices and physical  channel types, allows developers to avoid User input for application deployment. The example below uses the DAQmx System Property Node to isolate the first available Digital Input (DI) lines, and forwards a selected subset for DAQmx Task configuration. This example is meant to be demonstrative of the available System and Device properties that may programmatically be extracted. Further logic may be implemented to isolate specific device names, bus types, or additional I/O types.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device with at least one counter
1.Download the attached VI.
2. Set the DAQ device.
3. Run the VI.
Patrick Corcoran
Application Engineering Specialist | Control
Comments
Fraktur
on
Demonstrates the DAQmx System and DAQmx Device realtionship very well. A link to this in LabVIEW Help would be nice.
sha4790
on
This was useful but, the output of the subarray function will not get into the input of DAQmx-create-channel.vi function...
The required input format is as given on this link: https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/physchannames.html
So what is required to be done and I cannot find a way to do is:
- the output of this VI is of the 1D array of physical channels format.
- the required input format for DAQmx task configuration - even for multiple channels is "physical channels" and all the channel names have to be listed as given on the link towards the end.
The out to input incompatibility is what i want help for...
