Example Code
Programmatically Populate a Tree Control
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This VI shows how to programmatically populate a tree control using the Edit Tree Items.Add Item invoke node.
Description:
It will create a parent item, a child to that parent and a grandchild to the parent.  This example also shows the difference between the "Left Cell String", "Child Text" and "Child Tag" inputs of this invoke node.
Requirements:
LabVIEW 2012 (or compatible)
Steps to Implement or Execute Code:
  1. Open the VI "Programmatically Populate Tree Control.vi"
  2. Run the VI
Additional Information or References:
Front Panel:
Block Diagram:
Notes:
By calling the Edit Tree Items.Delete Invoke node with the Tag input unwired, LabVIEW will delete all items in the tree control.
If you do not wire the "Parent Tag" input or wire to it an empty string constant, this will create a top level item.  This is what is done in the first "Edit Tree Items.Add Item" invoke node.
Comments
HunterSeeker
Member Member
on
Could You include an image of your front panel so we can see what the tree control looks like?
David_L
on
Consider it done...
joshuatree
on
you should check out this tree toolkit on LAVA...
http://lavag.org/index.php?app=downloads&showfile=27
Taronmnats
on
Thanks that was helpful
