Example Code
Programmatically Change Tab in a Tab Control in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI has buttons that allow the user to programmatically switch from one tab to another.
Description
This demonstrates one way to programmatically change the tab on a Tab Control.  The Tab is made an indicator, which means it does not directly take user input.  Instead, it takes a value from a wire and changes based upon that.
An alternate method would be to make the tab a Control and then update the value programmatically with a property node.
Requirements
LabVIEW 2012 (or compatible)
  1. Run VI.
  2. Click 'Go to Tab' buttons and observe the tabs changing.
Additional Images or References
**This document has been updated to meet the current required format for the NI Code Exchange.**
Claire Reid
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting!
Todd S.
LabVIEW Community Manager
