Example Code
Programmatically Add Elements to Enum / Ring
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will show you how to programmatically add elements to an enum or a ring.
Description
You cannot run this code if the actual control is in memory. This means that you cannot change the control and use it at the same time.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached ZIP file
  2. Open the enum or ring control (.ctl) you want to add elements to (i.e. Enum Control.ctl)
  3. Specify the filepath of the control opened
  4. Run this VI and see the new elements in the opened control.
Front Panel
 VI Snippet
Applications Engineer
Comments
VIMaster
on
Tried code ...._lv80.zip.
It is not made clear that you must first OPEN the enum control front panel, run the VI, and then SAVE the enum control which now has changed elements.
My goal is to replace a semi-automated enum stuffer with a completely automated method and this helps.
Thomas Plummer
LabVIEW programmer, 15 years.
GIC-VS_M
on
Further "evolution".
Hope it helps someone.
21st November 1905: E=mc² → and Physics would never be the same again...
