Example Code
Programmatically Acquire Screenshot in Executable Application
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This example uses calls from the Windows user32.dll to programmatically take a screenshot, access the image stored in the clipboard, and save the image to a file. This method can be used in a deployed application whereas innate LabVIEW methods (Clipboard.Get Image) as not available at run-time and cannot be used in an executable.
How to Use
  1. Use snippet below or download the attached LabVIEW code.
    • Provided code is compatible with LabVIEW 2012 and later.
  2. Run VI
**Note that the VI must be set to run in a single thread (run in UI thread).**
James K.
Applications Engineer
Comments
h_yong
on
Hi, I'm trying to run this on LV2011F2 and get this error when tryign to save:
Error calling method System.Drawing.Image.Save, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
    Inner Exception: System.Runtime.InteropServices.ExternalException: A generic error occurred in GDI+.) <append><b>System.Runtime.InteropServices.ExternalException</b> in PrintScreen-LV86-4.vi
Any ideas? This happens with both the VI and a compiled executable. I do have the execution set to UI. Thanks.
FireFist-Redhawk
on
For anyone who experienced it, in order for this to work in runtime environment, you have to set up the Call Library function node the way that this thread shows:
https://forums.ni.com/t5/LabVIEW/application-crash-report-user32-dll/td-p/2414136?profile.language=e...
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Biiiiiiiiiiil
on
For win10 and win11, you should disable Setting>Accessibility>Keyboard>Use the Print screen key to open screen capture. Otherwise it will popup the screen capture tool.
