Example Code
Programatically Center Front Panel Object Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to programmatically center an object on the front panel based on the window's size.
Description
This VI takes the size of the window and then positions the Object in the middle of the coordinates. It is really a demonstration of how you could build this into your own code. You can then create your own positioning, playing around with the coordinates, and place additional objects.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Run the VI
  2. Observe the Waveform Graph centered on the front panel
  3. To stop the VI, Press the stop button
VI Block DiagramProgrammatically Center Front Panel Object Using LabVIEW  BD.jpg
 **This document has been updated to meet the current required format for the NI Code Exchange. **
ColeR
Field Engineer
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting!
Todd S.
LabVIEW Community Manager
cha@bellflight.com
on
If I have a group of objects, it would be tedious to repeat the same "Waveform Graph" procedure to center each object. Is there a better way ?
cha@bellflight.com
