Example Code
Print Dialog
Code and Documents
Overview
This example is developed to populate the windows print dialog / printer seting window.
Description
This example is developed to populate the windows print dialog / printer seting window. And it is developed using .Net control.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attachment to your computer
  2. Open the VI "Print Dialog 2012 NIVerified.vi"
  3. Run the VI
VI Snippet
Regards
Prabhakant Patil
Comments
Prabhakant_Patil
on
Please click on like if you like it.
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Regards
Prabhakant Patil
PragmaTest
Member Member
on
The windows opened is not modal, or not in front of all the others already opened.
It could be a problem
HermanYang
on
I want to combine your program with a file input, I set printer to be color but still print B/W.The other problem is the printer properties can't show up.
