Example Code
Preventing Windows computers from sleeping or hibernating progamatically
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This project will prevent the system from sleeping when run.
Description
There are plenty of ways of preventing a PC from sleeping or hibernating. The problem with most of them is that they require your user to remember to turn them on when running LabVIEW. If you just set the PC to never sleep then it will never go to sleep but what you really want is for it only to stay awake when collecting data with your LabVIEW program. Or you could run a third-party program like Caffiene to prevent the PC from sleeping, but this has the same problem.
Windows has an elegant way to deal with this, they are called Power Availability Requests. have you noticed that your PC never goes to sleep when watching a video? These are Power Availability Requests in action. You can make you LabVIEW program behave the same way.
Requirements
  • LabVIEW 2012 (or compatible)
  • Windows 7 or above
  1. Unzip “Power Request Master 2012 NIVerified.zip”
  2. Open “Power Request 2012 NIVerified.lvproj”
  3. Run " Demo.vi"
VI Block Diagram
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Comments
RobertoBozzolo
Proven Zealot
Proven Zealot
on
Thank you for this example! Informations you reported on MSDN were very helpful as I'm very often facing the problem of systems not properly confguired for unattended, long-lasting tests.
I managed to develop a similar example for LabWindows/CVI: you can find it here.
Ben_Manthey
on
Thanks, glad I could help.
—Ben
—Ben
Use Power Requests
drjdpowell
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
Very useful.   But I suggest you make your cleanup functions, "Power Clear Request" and "Clear Handle", operate even if there is an error input, following the usual LabVIEW error-handling convention.
Ben_Manthey
on
drjdpowell,
I've updated the Git repository per your suggestion.Thanks!
—Ben
—Ben
Use Power Requests
Porter
on
Thanks for sharing this.
Have you tested it on Windows 10?
I'm assuming that the Git repository is this one: https://github.com/benmanthey/Power-Requests
Ben_Manthey
on
Porter,
     You're welcome,
     Yes to both your questions.
     It works fine on Win 10 and that is my Git repository.
—Ben
—Ben
Use Power Requests
