Example Code
Pairing Wii Remote "Wiimote" (or any bluetooth device) programmatically using a managed .net library in LabVIEW
Code and Documents
Introduction
There is a fantastic resource for accessing Wii Remotes and getting data from them here however this code requires you to use Windows to pair the Wii Remotes before you can run the VI and this prompted me to find a way of doing this also from LabVIEW.
32feet.NET from In The Hand is a great library for programmatically pairing Bluetooth devices and accessing services on that device. Using this library in LabVIEW allowed me to create an all-in-one solution for pairing and accessing Wii Remotes.
Front Panel
I have attached the LabVIEW 2009 VI as well as the latest (as of 24th Feb 2010) version of the Managed Library. To use the VI, press 1 + 2 on the Wii Remotes to make the LEDs flash then run the VI.
Comments
ssingh1
on
Nice One, thanks. 🙂
Ashish_Naik_NIUK
NI Employee (retired)
on
Looking forward to getting some good use out of this!
Ashish Naik
Automotive Business Development Manager
National Instruments UK
paljacob
on
Superb! It works great, thanks!
Is it possible to make a subBluetoothDisconnect.vi?
Mark_SAI
on
Hi, I have actually made a very comprehensive set of VIs for the wiimote but they aren't ready to be released yet. In the meantime, I have a tip for you on how to disconnect the wiimotes after program execution:
- Place a .net reference on your front panel. Navigate to InTheHand.Net.Bluetooth.BluetoothSecurity, to create a Bluetooth Security reference.
- One of the methods (invoke node) of this is RemoveDevice.
- All you need to do is pass in the DeviceAddress (from the DeviceAddress property of a BluetoothDeviceInfo node)
~Chris.
on
Hey this is excellent!
I was wondering if anyone has had success using this VI to connect a wii balance board?
If I understand correctly, the balance board uses the same bluetooth protocol as the wiimote, so I would expect it to work (but it doesn't).
I'm trying to connect under windows 7 32bit but the device driver fails to install.
Has anyone tried this?
Thanks.
Ruff
on
Thanks so much for your effort.
This will be so helpful in my further endeavors in my wiimote robotcs project for class.
ThiCop
on
Hello macaba,
Based on your code I have created a very basic class-based API that implements some of the functionality you've used here.
I abstracted your code to a set of higher-level "easy-to use" VIs:
https://forums.ni.com/t5/Archive-TKB/Basic-Bluetooth-Discovery-Pairing-and-Virtual-COM-Port-Creation...
Please note that I have fully credited your example as inspiration.
Thierry
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
rfandrade
on
I've tryied to call the dll using the "Call Library" function, but it appears the next message: "The library selected is not valid for the current platform. For example, you are running 64-bit LabVIEW and the library might be a 32-bit library".
This dll doesn't work for 64-bit platforms?
ThiCop
on
As far as I know the dll posted above is a 32-bit DLL (from the external 32Feet library), so you cannot directly call it from LabVIEW 64-bit.
More information about why it's not possible can be found over here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PA7SSAW&l=en-US
Is there a specific reason why you need to use LabVIEW (64-bit) instead of LabVIEW (32-bit)?
Thierry
Kind Regards,
Mark_SAI
on
Grab the latest version of the DLL from the developer's site, this should work for 64-bit. You may need to tweak the LabVIEW code as it is likely the DLL methods may have changed (this example was released 3.5 years ago!), Thierry could probably tell you if this is the case (assuming he got the latest DLL in his example code).
Albert.lu
on
I used your program,and when pairing,windows 7 will appear below windows,is there any way to disable this,or progammaticly click next button?tks
ganquetil
on
Hello ,
Thank you for your works, but I didn't find the attachment, where is it ?
Contributors
