.NET Serial Port Write and Read Using LabVIEW
Productos y Entorno
Esta sección refleja los productos y el sistema operativo utilizados para crear el ejemplo.
Para descargar el software de NI, incluyendo los productos que se muestran a continuación, visite ni.com/downloads.
    Software
  • LabVIEW
Código y Documentos
Adjunto
Overview
This example shows how to use the .NET Serial Port Class with a remake of a classic VI, the Serial Basic Write and Read.
Description
This is useful if you don't have the VISA driver installed on the machine.  Note that this class is found in version 2.0 or higher of the .NET Framework.
Requirements
  • LabVIEW 2012 (or compatible)
1.Select a port of serial device, configure serial setting.
2.Run the VI, and write to the string
VI Block Diagram
El código de ejemplo del Intercambio de Código en la Comunidad de NI está autorizado con la licencia MIT. 
Comentarios
JPowell
el
Thanks much for this.  This gave me what I needed to talk to an old spectrometer that needed some wierd delay settings for the serial port that normal VISA couldn't do.
Jeff'sGPIB
el
Hi,  I see this is an old thread.  I have a new comment.  First, thanks!  This is a good example of .NET.  Most appreciate.  What I am trying to do is to discover what com ports are available.  i.e. get a list of com's. programmically.  I see in this example, the com name is a string and it is given.  How would I discover what com's are available?
Thanks JeffsGPIB.
JPowell
el
Hi Jeff,
First, go to the connectivity palette and there to the .NET palette.  Select Constructor.  Once the constructor is placed, a dialog will pop up so you can select what creator to use.  In the Objects section of the dialog box, select System, then System.io.ports then click on Serial Port.  In the Constructor section, select the SerialPort() object and press OK.  Now, right click on the constructor and select create, then the option that says Method for System... .  Then, select GetPortNames().  An invoke method node will be created.  In my test VI, I just connected the output of the invoke node to an indicator.  You will be able to delete the constructor at that point.  See the attached image for an example and the results on the front panel.  You can also get the example at https://decibel.ni.com/content/docs/DOC-43774 along with a version of the example from this page, in which I used the example code.  I created that page, since I couldn't attach the example here.
John
