Overview
This example VI demonstrates the method of programmatically Changing the Properties of a Boolean Button.
Description
A property node in LabVIEW allows you to programmatically change a property associated with an object such as a control or an indicator.
To create a property node from a control or indicator, all we need to do is to right-click on the control/indicator, then go to Create >> Property Node and select our desired property.
Requirements
VI Block Diagram
This is a very useful example for those of use learning property nodes. How do you guys make the run bar disappear upon startup of the VI?
