Example Code
Modifying a Boolean Control Using Property Nodes
Code and Documents
Overview
This example VI demonstrates the method of programmatically Changing the Properties of a Boolean Button.
Description
A property node in LabVIEW allows you to programmatically change a property associated with an object such as a control or an indicator.
To create a property node from a control or indicator, all we need to do is to right-click on the control/indicator, then go to Create >> Property Node and select our desired property.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " Property Nodes with Booleans 2012 NIVerified.vi"
  2. Run the Program.
  3. Change the properties of the Boolean Button by pressing any button below it.
VI Block Diagram
Tori
Student
Comments
digital71
Member
Member
on
This is a very useful example for those of use learning property nodes.  How do you guys make the run bar disappear upon startup of the VI?
