Example Code
Mini Animation Package
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example is a simple 2D Drawing and Animation tool.
Description
You impliment a series of doodles on the drawing pad, and then play the drawings at a configurable frame rate to view the animation.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Doodle on the Drawing Pad
  2. Select Next Frame to create a new frame in the animation
  3. Repeat instructions i & ii, until you are happy with your creation
  4. Hit Done
  5. Watch in amazement as your doodles come to life
  6. Hit STOP when you grow bored of your creation
Front Panel
The tool includes an animation technique called Onion Skinning - when you create a new frame, the drawing pad retains a grayed-out version of the previous frame. This aids the animator in the creation of smoother animations.
http://en.wikipedia.org/wiki/Onion_skinning
Before stopping the application, the user is prompted to save the animation as a series of bitmaps, which can be viewed at a later stage or uploaded to an online gif generator, such as http://gickr.com/ or http://www.gifup.com/
The images will be saved in a sub-folder called Saved Animations inside the application directory.
I would like to work on producing an animated gif directly from LabVIEW, but have been unable to do this so far. If any esteemed members of the community would like to help me, I would be very grateful.
The challenge has been set!!!
I have also attached an example animation, created with the tool, called Fireworks.gif. It is certainly not going to get me a job at Pixar.
VI Snippet
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
Comments
JohnMc19
on
Amazing! Nice work.
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
Tom9390
NI Employee (retired)
on
Love it
G-Money
on
Nice job. What are you wanting to do with gif in LabVIEW? Just create a gif file or to view it? There are some users on our forums who have used gif in LabVIEW in the past (http://forums.ni.com/t5/LabVIEW/GIF-Reader-VI/m-p/796039?view=by_date_ascending#M363305).
ECNU
on
creative job~
AmitKaria2k
on
Good job.. Keep it up !
SwapsG
on
Nice...
jawadtld
on
Nice work.. keep it up..
