Make Front Panel Fullscreen While VI is Running in LabVIEW
제품 및 환경
이 섹션은 예제 생성에 사용된 제품과 OS를 표시합니다.
아래의 제품을 비롯한 NI 소프트웨어를 다운로드하시려면 ni.com/downloads를 방문하십시오.
    소프트웨어
  • LabVIEW
코드 및 문서
첨부파일
모두 다운로드
Overview
This example expands the Front Panel size to fit full screen except the task bar
Description
This VI will take the desktop space available and fill it with the front panel. Once the stop button is pressed, the VI takes the initial values for the front panel, before it is ran, and returns it to the original size.
Requirements
LabVIEW Base Development System 2012 or compatible
Run the VI, the Front Panel will fill the full screen area
Press the Stop button to restore the window size to its initial size and location before running the VI
VI Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Chris Van Horn
NI 커뮤니티에 있는 예제 코드 교환의 예제 코드는 MIT 라이센스로 라이센스가 부여됩니다.
의견
D.Romito
Member
Member
날짜
Without you I'd never find that App Property Node.
Special Thanks.
juventino001
Member
Member
날짜
thanks
juventino001
Member
Member
날짜
good evening
anyone knows how to video (WMP), activating you the fullscreen option
excuse the translator
Thank you for the cooperation
