Example Code
LabVIEW LED Scrolling Reader Board in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
1. Overview:
This VI simulates a Led reader board
2. Description:
This VI will take any text (or the current time) and convert it to a binary array to display on the front panel as if it were an electronic LED reader board that you see on signs.
3. Requirements
  • LabVIEW 2012 (or compatible)
4. Steps to Implement or Execute Code
  1. Unzip "LED Scrolling Clock LabVIEW 2012 NI Verified.zip"
  2. Run "LED Scrolling Clock LabVIEW 2012 NI Verified.vi"
  3. Display Time button enabled will display time and when in disabled state it will display the text introduced
5. Additional Information or References
VI Block Diagram
Comments
Doug_S
NI Employee (retired)
on
Please include GetTextBitmap.vi and any other subVIs.
Thanks!
StevieZ
on
It should be there under "Downloads". Let me know if you are still having trouble getting it.
origin
on
If possible, can you save it to LV 8.5 version and post it
StevieZ
on
Posted versions for LabVIEW 8.2. These should load in any version of LabVIEW after 8.2 just fine (including 8.5). Let me know if you are having any problems opening them.
origin
on
It's a cool stuff..  Thanks Steven..
Athin
on
Hello!
Can you please tell me how to make scrolling from bottom to top?
Thank you!!!
StevieZ
on
A simple transpose of the array should do the trick. Place a Transpose 2-d array inside the while loop and before the for loop. Then place another one just after the for loop.
Athin
on
Thank you!!!
It works,
Is there an solution for adding a zero line array between each array?
arifi
on
could you inform me how to make such scrolling but with series of images in a folder of image?
josufire
on
How to change the meaning of the text, that is, to go from left to right?
