Overview
This example shows how to use an event structure to implement a calculator in LabVIEW.
Description
The calculator VI is a fully-functional calculator built in LabVIEW. This example demonstrates the following concepts:
Each time the user presses a button it is registered as an "event." Each type of event corresponds to a different case in the event structure, which implements the intended function. The "stored number" and "display number" are tracked via shift registers in an event machine, and the VI stops running when the running front panel is closed.
Requirements
LabVIEW 2012 (or compatible)
Front Panel While Running
Block Diagram
seminal work.
Awesome work. But it would be better if it was a bit more open-sourced.
Thanks for your work!
