Example Code
LabVIEW Calculator
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to use an event structure to implement a calculator in LabVIEW.
Description
The calculator VI is a fully-functional calculator built in LabVIEW. This example demonstrates the following concepts:
  • Dataflow Programming
  • Modular Programming
  • While Loops
  • Case Structures
  • FGV
  • VI Documentation
  • Passing References
  • Property Nodes
  • LabVIEW Projects and Application Builder
Each time the user presses a button it is registered as an "event." Each type of event corresponds to a different case in the event structure, which implements the intended function. The "stored number" and "display number" are tracked via shift registers in an event machine, and the VI stops running when the running front panel is closed.
Requirements
LabVIEW 2012 (or compatible)
  1. Download the attached file "Calculator_LV2012_NI Verified.zip"
  2. Unzip the folder to your computer
  3. Open the "Calculator_LV2012_NI Verified.lvproj" file
  4. Open "Calculator.vi" and hit the Run button
  5. Perform desired calculations
  6. Close front panel when finished
Front Panel While Running
Block Diagram
Comments
ReneW
Member
Member
on
I like this example. It gives me a lot of inputs.
syrpimp
Member
Member
on
seminal work.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Shlok1229
Member
Member
on
Awesome work. But it would be better if it was a bit more open-sourced.
ChanMin
NI Employee (retired)
on
Thanks for your work!
