Example Code
LabVIEW - Calculator Example
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Calculator application using LabVIEW
Description:
The calculator can perform a number of simple mathematical operations and utilities the Producer/Consumer (Events) design pattern. When running the program, hover over certain buttons to display a tip strip as to their operation. When analyzing the block diagram, display Context Help (Ctrl-H) and hover over SubVIs to get a description of functionality.
Instructions:
To implement this example:
  1. Run VI
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Peter D
Comments
Tori.M
on
Hey,
Liked the calculator but quick suggestion would be to switch the numbers around so that they replicate the order in the num pad & not a telephone!
Also I did notice that you've copied the standard windows calculator, and not the scientific one that follows BODMAS e.g. 8 + 2 * 9 it thinks = 90, not 26. Another suggestion could be to implement a little extra code to switch between the two perhaps?
Other than that, nice work!!
Tori
Student
RER
NI Employee (retired)
on
That is a slick architecture Pete.
Nice coding!
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
alecjcook
on
Hi, could someone please tweak the "Calculate Results" sub VI so it operates on BODMAD principals. My programming is OK but my maths is shakey, could someone help please!
Many thanks
e.ono
on
I love this example, thank you!
