Example Code
Inverted Pendulum Digital Prototype and Control System (SolidWorks 2013 & LabVIEW 2013)
Code and Documents
Using NI LabVIEW, Control Design and Simulation Module and SolidWorks.
This example sources also exist as a continuously evolving example in the LabQT LGPL Open Source Library.
Below is a video illustrating the example:
Source code and CAD models included.
Comments
Eng.Tareq
on
can i have the files of this project for Labview 2010?
thanks
User002
Not applicable
on
Hi Tareq,
I have not been able to run a SW 2013 assembly in LV2011, so I presume that the LV/SW API have to be of the same year/release?
Unfortunately I dont think there is a way to save SolidWorks parts and assemblies from 2013 to 2010.
I'm sorry I could not provide any help this time.
Br,
/Roger
Eng.Tareq
on
hi,
i need Labview file to be run in LAbview 2010 not Solidworks
solidworks i think ok because i have 2013
thanks
User002
Not applicable
on
Tareq,
I updated the document with a LV2010 and SW2013 version. See if you get it to work.
Br,
/Roger
Eng.Tareq
on
Thank you very much i will check it as sson as possible
because i have to finish my master thesis before 20th of may
thanks a lot
mayma
on
User002
Not applicable
on
Are there VI's missing? Let me know which ones!
Br,
/Roger
atul_rk
on
hi sir
i have been trying to develop a self balancing inverted pendulum using labview softmotion.i'm using a kollmorgan servo motor and akg drive for actuation parts.. in the example given i have seen position method is being used. i'm trying in same way but i couldnt get satisfactory results. can u help me in solving this
User002
Not applicable
on
I am not sure if your question belongs here?
Perhaps you should check some other forum regarding your motion feedback control questions? A good place to start is NI's own Motion Control pages, you can navigate yourself from there.
http://www.ni.com/white-paper/3367/en/
Br,
/Roger
Contributors
