Example Code
Image Resize and Image Convert function (.NET) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI shows how to resize image and convert format for images when default interpolation mode is sufficient.
Description
You can resize image and convert format for images when default interpolation mode is sufficient.
Requirements
  • LabVIEW 2012 (or compatible)
1.Selection the path in the front panel.
2.Run the VI
VI Snippet
Comments
fjimage
on
it is marvelous to see the image resize vb.net map there. cool job. when can the default interpolation be sufficient.
