Example Code
ISO-8601 compliant date/time string in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example transforms the input date and time to ISO 8601 Standard
Description
This example creates an ISO-8601 compliant date/time string using various LabVIEW format specifiers. If no timestamp is provided, the current time is used.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Enter the Date and Time Part in the same format as indicated
  2. If no date and time is entered the current time will be used
  3. Select whether to show the Time Zone, Basic or Zulu
  4. Run the VI
 Wikipedia entry for ISO-8601
VI Block Diagram
 SubVI Connector Pane
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
J.CHEN
on
More developement work has been done here and shared as open source project. A very comprehensive set of time zone libraries. You can also find the package via JKI VI Package manager by searching for "Epoch"
https://github.com/LabVIEW-Open-Source/Epoch-Time
