Overview
The example demonstrates how to acquire images and save them to series of images or a video.
Description
The example shows how to use an IMAQdx Get Image to save each frame as an individual image file (formats: BMP, JPG, PNG) or a video (format: AVI). In case the frames of the camera acquisition are saved in image files the file name is automatically incremented.
Requirements
Software
Hardware
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Dear All
i just tried this vi it works well
thank you so much
hello
i have labview 2011 it didn't work for me 😕 can you tell me how to fix it ? thank you
Hi, I used your example VI "Grab and save to jpg".
Everything works fine, but I only see blue images. This happens with both my cameras, a "ZWO ASI290MM", and a "Tuscen IS300". Both of them work fine with their native image viewer software. However in labview it only gives blue image.
Does anyone face this problem too?
I have edited the sub VI to test it out, and the image returns a blue screen even when I link the IMAQ temp memory storage straight to the indicator. Below is the edited VI. (I get the blue screen even when using the unedited version), also the blue image and the numbers below fluctuates a little using both the edited and unedited VI, which is strange cause the same data goes into the while loop.
