Overview
This library uses the COMTRADE format to gather data vectors and write them to a COMTRADE file.
Description
The COMTRADE format is a standardized file format used in power system monitoring. The measurements are recorded in ASCII or BINARY format. COMTRADE files always come by pairs: The ".CFG" file describing the configuration: number of analog and digital channels, sampling rate, scale factors, etc. and the ".DAT" file containing the data the library gathers. The library file contains a VI which reads COMTRADE files, a VI which writes vectors of data to COMTRADE files, a VI which creates only the ".CFG" file, and a VI which appends a buffer to an existing ".DAT" file. The format chosen for this example is to bundle a time vector with each measurement channel (easy to plot in XY graph). Analog and digital channel descriptions are represented by an array of clusters. For any comment, please feel free to contact me.
Requirements to Run
Software
LabVIEW 2010
Hardware
N/A
Additional Images
LLB Manager With Comtrade Examples
Hello..
Is the attachment contains many comtrade files presenting many types of fault and disturbance? i have downloaded the attachment but i cant open it? Could u help me. Tq sir.
You done Great Job.......:-)
I'm trying to use this library to write COMTRADE files. My objective is to read a csv file containing a time vector and several signals vectors and convert it into COMTRADE files. My main problem is that I can't find where I have to put my input data (from the csv) in order to obtain COMTRADE files.
Do you have an example vi that uses "Comtrade Writer optimized.vi".
Thank you!
