Overview
This VI allows you to use Google Static Map to search for a specific location (defined by latitude and Longitude), pin it and draw the path with another point.
Description
The code was made using state machine design pattern to enable you to place more than 1 point on the map, draw the path between 2 selected points and update the map properties i.e. size, zoom and format. Each time you use the Google Maps APIs you must include a key, or other credentials, to validate your request. To get a Google Maps API key, go here
You can use this VI to set a specific location or in GPS tracking applications.
1. Download the project and open Google Static MAPs API_LV2012.vi
2. Open the block Diagram and Navigate to Update Map state
3. Enter your Google Maps API key after you create it from the above link
4. Run the VI
5. Choose the Latitude and Longitude
6. Clock on Add Marker. You can add another one if asked or click on cancel
7. If you modify the parameters click on Refresh
8. Choose the 2 points from Path Properties then click on show path to display the path between them.
9. Stop Execution
Requirements:
LabVIEW 2012 (or compatible)
Front Panel
Block Diagram
Nice job using the Google API. The next natural step it seems might be to do this using Google Maps in offline mode. This would be useful for applications where you have a data feed for position but don't have a connection to the internet. Any thoughts?
Dear, I like your concept (not runned the program yet). I have list of 3000 sites + [latitude and longitude in ms excel] for which i need to bookmark/ balloon and find distances / time for each site. Doing this manually is very hectic. Please guide me to make a loop which would take data from : 1) Excel file. 2) Bookmark in googlemap [with site name]. 3) find distance for n number of site/s. 4) find hour between each site/s. 5) output in excel form and google map page. site1 site 2 ...... site1 0 km 15 km site 2 300 km 200 km . . . Secondly to download API they are asking URL (which i dont have), so would your tweaks work. Thanks Usman
Dear macaba
I think youre API application very interesting, with a lot of applications. I downloaded ur zip file and when I try to download the Google API they ask for my URL. We need a http server to use your LabView application ?
Thanks in advance
Thanks a lot for the job! That's very useful!
I also agree with mtat76 - offline mode would be super
Man very nice and many thanks
May god bless you
thank you
one thing tough, I was able to use it without getting a key!
how is that posible.
anyways, when i went to get a key, i was asked to choose one of these options, which one do you think is relivant to labview?
1- Google Maps JavaScript API v3
2- Google Earth API
3- Google Maps JavaScript API v2
4- Google Maps API for Flash
excellent job, this works without the key!
Hi
I am using this code to access the Google Maps and it works; but can not put a balloon for the new coordinates that i'm entering for Longitude and Latitude. How can I solve this problem?
Thank you!
Hi Andrei02 and Macaba,
How can it work? Can you please give me some advise.
I have tried this code but it is not work without API key.
I am trying to create some Google API key, but I got only 40 Character (not 86 character key no matter which API type)
and this API key does not work with code.
Moreover, when I copy url and paste to google chorme, it showed that this ulr need different API key.
Thank you in advace
Chomphunut N.
Other example of using Google API
https://decibel.ni.com/content/docs/DOC-12505
Hope will be useful!
Hi Team
How can I using labVIEW with Google offline maps api?
Luong.Tran
Hi!
Have you this program for LabVIEW 2012???
Igor
Technically, it is opened in LV2012 without any issues.
How can i get 86 key google maps api? thx
Thanks, this was a great starting point. The URL doesn't require a key anymore but the starting point of the URL has changed: Use maps.googleapis.com instead.
For example
http://maps.googleapis.com/maps/api/staticmap?center=Brooklyn+Bridge,New+York,NY&zoom=13&size=600x30...|label:S|40.702147,-74.015794&markers=color:green|label:G|40.711614,-74.012318&markers=color:red|label:C|40.718217,-73.998284
You may also google for "static map api" and find a lot of additional information. There some alternatives to be found at https://justmarkup.com/log/2014/05/27/overview-of-static-map-solutions/
hi, i'm using your code thank you
and i have a question. java program is used in this process? please answer my question
Because only an image of google maps handled as podriar make out more images please answer my question
I could explain how his ballon work because I do not mark the spot?
Muy buen aporte me sirvio de mucho, para los que tengan problemas con la API este programa funciona sin API pues google a modificado, solo debe arreglar como se esta generando el link que deberia ser de esta manera http://maps.googleapis.com/maps/api/staticmap?center=-3,986791,-79,199378&zoom=16&size=572x350&mapty...
Al igual los que tienen problemas con generar el puntero dentro del mapa unicamente deben arreglar el link,
Hello.
I tried using the key you mentioned, but it does not work.
http://maps.googleapis.com/maps/api/staticmap?center=Brooklyn+Bridge,New+York,NY &zoom=13&size=600x3...|label:S|40.702147,-74.015794&markers=color:green|label:G|40.711614,-74.012318&m
Can you please help me with this? How do I get a key for myself?
Thank you
Hello ishraque,
This URL doesn't have a key. The API also works without a key but will has a low limit on the numbers of maps you can retreive on one day. I checked the link in your post on another machine and it works fine.
You only copied a part, the section after the 'm' should become 'markers....' from the previous line but works fine as you copied it as well. Even when you only click the hyperlinked in your post. What do you get?
Kind regards,
Mark
OK,
I didn't use the vi, just copy the URL in your browser. The vi creates it's own URL which has the key field. If the key field is present it must be used. You can use the URL that I supplied to debug the call string generated by the vi.
If you don't want to use a key (for quick starting, to see how everything works) remove the last two inputs of the upper build string (the constant '&key=' and the API key control.
How to get a key for the google API changes every now and then... Best is to 'google' it. Seems they changed it again starting this year: https://developers.google.com/maps/faq?hl=en#keysystem . This method use the webapi so you need a browserkey.
hello,
i got a smilar error as ishraque1 , however i created a browser API but it wasnt of length 86 alphnumeri, instead it was 39. To be honest i have no idea where to enter the API key
please help
if i wanna use this code with arduino and gps module , how can i do it (what should i learn )
I have tried this VI.For the marker and center worked fine. But when i tried to make a path, it did not show any path (Geocoding error:path 1)
Later i found out that when we use path parameter, we should not include other parameter like marker, center and zoom. So rather than adding parameter, i modify the VI so it choose only 1 parameter.
Am i the only 1 who encounter this?
If you are using arduino, you can control it through LIFA or LINX (Download it from VIPM) or control it through VISA("You should also program the arduino to communicate serially to PC). I see some labVIEW compiler for arduino, maybe you can try it and share it with us.
For GPS module, you should learn about the protocol your module use. Usually it uses NMEA protocol. For this protocol, to put it simple, you only need to configure UART to write(Send command(Proprietary sentence) to the module and to read (Receive NMEA response). To obatain your location , speed and etc, just parse the NMEA response.
Does it help?
Hello is there someone who can s197753_API.PNGend me the version of the program shown in the picture.
Can me full tutorial step by step for trajectori GPS with maps in labview?
The code to date continues to work well in my case. Although, the trajectory function is not executed. When creating the API key to access Google Maps, a restriction must be assigned to the API key and the external IP address of the computer.
