Example Code
Get Windows Shutdown Status Using LabVIEW
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI demonstrates how to get Windows shutdown (reboot) state, so your application can finish properly.
Description
This VI can be useful when application cannot be run as windows service but must exit properly on shutdown or reboot.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Use this VI as a subVI.
VI Snippet
Comments
r_exler
on
For me this VI just creates error (LabVIEW 2013, Win7 64 Bit OS)
Error 1097 occurred at Call Library Function Node in WindowsShutdownStarted.vi
Possible reason(s):
LabVIEW:  An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW.
GriffinRU
on
Try to change Calling convention from "C" to stdcall (WINAPI)...
-Artur
r_exler
on
Hi Artur, at least it worked on an old, slow Win32 system.
On my i7 based Win7/64Bit notebook the application gets killed by windows before it recognises the shutdown being started!
Some notes on my application, might be interresting for others as well: I'm doing durability tests on stepper motors and need the test to run over several months. To prevent the test interrupted I have an UPS system which is capable to power all the hardware including the controlling notebook for about 10 Minutes - this should be enough to overcome most power outages. In case the mains power fails for a longer period I will use this to shut down the test, saving the progress and state to be able to restart after power restores.
Unfortunately the UPS does not provide an software interface to get it's status (e.g. Mains/Battery power) or estimated time to shut down, so the software can just respond to the shutdown initiated by the power supply monitoring software.
I hope there is a similar system call to test for a user log off, which will kill the application as well. Most likely I'll include this in several applications, as I frequently have seen the users to log off or shut down without closing the application both killing the application), leaving external hardware e.g. positioning systems, ... in an unwanted state and/or power supplies turned on (could be dangerous).
GriffinRU
on
How often you check Windows status?
As for UPS and Battery I will recommend to check WMI interface:
Example attached.
-Artur
P.S. User status can be obtain from WMI as well.
r_exler
on
I checked every 500ms.But my notebook is fast and closes the user interface within about 200ms after pressing the shutdown button - killing the labview application before it notices anything. Even if it would see the shutdown starting this would be too late.
I'll test your example on my notebook. On my Desktop PC it returns an empty array. Actually I will have to create a solution working with desktop and notebooks as well as supporting at least WinXP and Win7. And as you guess I'm not a programmer familar with windows specific things. Usually I'm programming LabView on Win and C code on embedded applications.
Thanks for your help!
GriffinRU
on
You should check faster, drop down to 10ms. Or write in C a DLL and let windows send you an event... MSDN my friend
Your app should be able to exit properly, unless windows thinks it is a stopped responding application. (You can extract more info by tapping into windows processes...)
Win32_Battery should work for Desktop if you have UPS attached
Win32_PortableBattery should work for laptop only
Win32_ComputerSystem should work for both
Win32_UninterruptiblePowerSupply should work for WinXP
-Artur
