Overview
This Example give you the LAN Settings like IP Address, Subnet Mask and Default Gateway.
Description
This example can be used in some project as an subVI to get the IP address, Subnet Mask and the Default Gateway.
Requirements
VI Snippet
Please click on like if you like it. ![]()
Your valuable suggestions are always welcome for the improvement.
Regards
Prabhakant
In my Vista system it needs "IPv4 Address" instead "IP Address" in the first string; otherwise it doesn't pick up the main IP address of my computer connected to a mobile internet modem. IPv4 works ok.
Hello Prabhakant,
I try to run the attached code but i am not getting Indicator output in IP Address. I try with both wire LAN and WIFI connection.
This doesn't work if you have a non-English windows installation. You can get a more robust implementation if you use the Windows IP Helper API. Is harder to implement, I know...
Example output on German Windows 2008 R2
Windows-IP-Konfiguration
Ethernet-Adapter LAN-Verbindung 4:
Verbindungsspezifisches DNS-Suffix:
Verbindungslokale IPv6-Adresse . : fe80::6cc9:c754:b1d3:4a57%16
IPv4-Adresse . . . . . . . . . . : 192.168.1.24
Subnetzmaske . . . . . . . . . . : 255.255.255.0
Standardgateway . . . . . . . . . :
Ethernet-Adapter LAN-Verbindung 3:
Verbindungslokale IPv6-Adresse . : fe80::5c7d:72e2:5cf9:25f0%14
IPv4-Adresse . . . . . . . . . . : 10.10.0.24
Subnetzmaske . . . . . . . . . . : 255.255.0.0
Standardgateway . . . . . . . . . : 10.10.0.1
Ethernet-Adapter LAN-Verbindung 2:
Medienstatus. . . . . . . . . . . : Medium getrennt
Ethernet-Adapter LAN-Verbindung:
Tunneladapter <removed>:
Tunneladapter LAN-Verbindung* 9:
Better Language & OS independant version: http://digital.ni.com/public.nsf/websearch/B668D57C2E96C96C862572F40078FC96?opendocument&Submitted&&...
I want to access data from Wifi Arduino Server to Labview ..... However, I can access data from arduino server by typing adress 192.168.100.5 in any browser over wifi. What should I do ?
eu usei muito bom , porem como é em portugues tive que alterar cluster
I used very good, but as it is in Portuguese I had to change the cluster
