Overview: Generate array with equally spaced array elements.
Description: The example gets the difference between the two Maximum (end) and Minimum (start) then divides the difference on the number of samples needed. Then it generates a 1D array of all the elements within the Minimum and Maximum values including the start and end values. The code also checks if the inputs are valid or not.
Requirements: LabVIEW Base Development System 2012 or compatible.
Steps to Implement or Execute Code:
- Enter the Minimum value (start value)
- Enter the Maximum value (end value)
- Enter the Number of samples (number of elements)
- Run the VI
VI Code Snippet
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
