Example Code
Find Minimum Value in Array, Remove it, Average Remaining Values in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates two methods of searching an array of values for the minimum value. Then removing the minimum value from the array and averaging the remaining values.
Description
The Find Lowest Value in Array Take Average VI performs the following steps:
  1. The VI searches the array for the minimum value and the index of that minimum value.
  2. Deletes the minimum value element from the array and calculates the number of elements in the array.
  3. The VI then divides the resultant array by the number of elements.
The Find Lowest Value in Array Take Average Modified VI performs the following steps:
  1. The VI searches the array for the minimum value, adds all the values of the array together, and calculates the number of elements in the array.
  2. The VI then subtracts the minimum value from the sum of the array and divides this result by the number of elements in the array minus one.
  1. Download and open the original or modified example
  2. Initialize the array with the values you wish to search or use it as a SubVI
  3. Run the VI and see the average value
Requirements to Run
Software
LabVIEW 8.6 or 2012 or compatible
Additional Images
Block Diagram of Find Lowest Value in Array Take Average
  Block Diagram of Find Lowest Value in Array Take Average Modified
**This document has been updated to meet the current required format for the NI Code Exchange. **
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting!
Todd S.
LabVIEW Community Manager
GregSands
on
I wonder if you know that the entire left-hand side of the VI (up to and including "Search 1D Array") could be replaced by the single function "Array Max & Min" found in the array palette, which returns not only the minimum, but its index as well.
Todd S.
on
I was thinking the same thing when I left my comment, but was too afraid to say...
Todd S.
rpursley8
on
See attached.  I runs 4-5 times faster on large arrays.
Randall Pursley
Todd S.
on
BOOM!  Nice work!
Todd S.
Will_S.
Active Participant Active Participant
on
I have no idea how I missed that function....oh well, thanks for the tip!
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
