Example Code
Find Enum Item from String Input
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to convert the string into the appropriate enum value.
Description
You would need to turn this into a subVI, then take the subVI output and use that as the case structure input. There is  a neater way: you can bundle it into a cluster, and then unbundle from your type defined enum placed inside a cluster shell.
Requirements
  • LabVIEW 2012(or compatible)
  1. Set the Combo Box.
  2. Run the VI.
VI Snippet
Joel G
Applications Engineer
National Instruments UK & Ireland
Comments
Rob_Ward
NI Employee (retired)
on
Hey Joel.
This will work too using the "Scan From String" function, but if your text doesn't match any of the entries in the enum, you will get an error 85 message.
Rob
Robert Ward
Applications Engineer, NI
crossrulz
Knight of NI Knight of NI
Knight of NI
on
I am also a fan of just using the Scan From String.  It does everything your code does, but faster and a whole lot smaller.
GCentral
Olivier_L
on
Whaou!
This trick with Scan from string is exactly what I needed!!
Actually, I used it from enum to string, but didn't know how to use it from string to enum.
The fact is that when you use an executable (particularly in RT), you can't access to "Strings[]" property because UI is removed, so property nodes don't work anymore. This trick will save my life ^^
Olivier L. | Certified LabVIEW Developer
Todd_Lesher
on
One caveat: if the enum contains "One", Two", "Three", and the string scanned from is "Oneasdf", scan from string will return the enum value "One".
David_Grucza
on
For Reference: You can simply cast an Integer to an Enumeration. I'd include a snippet, but it doesn't seem to want to upload.
MarceloA
on
Hi
maybe you can use this solution
