Overview
This example will return files paths to all of the root directories on your execution system.
Description
Returns an array of file paths pointing to the root directories on the execution target. This can be used to check for the presence of removable drives or adapt your code to different file systems.
Requirements
VI Snippet
The same thing can be done by using a List Folder primative with a empty path constant as the path input. The folders output will contain the drive leters without the ":\".
