Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Example Code
FPGA Motor Position Sequence 9505
Code and Documents
Equipment List
CRIO-9073
NI 9505 Full H-Bridge Brushed DC Servo Drive Module
DC Brushed Servo Drive
In this project I developed a demo using FPGA and NI-9505 Module to reproduce a set of 5 sequence positions in memory. This could be used for example to open a safe box given a sequence of the positions.
I used some example codes from LabView and created my own progamming to complement this project
Regards
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
Comments
Zaitouni
on
Hi James,
Thanks. Could you please advice on where I can find the 9505 DC brushed position (PID) closed loop FPGA target? I worked on it before in some previous version but in the current 2013SPI, it all about softmotion approch!
Contributors
