Overview
This VI demonstrates different ways of handling errors in LabVIEW
Description
The first method demonstrated manually creates an error cluster. The second method creates an error cluster when only given an error code. The third method is the standard error passing that many VIs implement. Finally, merging multiple errors is demonstrated. This example does not nearly cover all the different ways to handle errors. If you have other ideas that would be helpful, feel free to edit the VI and the VI Snippet and add them to this document.
Requirements
LabVIEW 2012 or compatible
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
A useful summary of a variety of techniques for handling or manipulating LabVIEW errors is found at: NI Community: LabVIEW Error Responses.pdf.
