Example Code
Error Handling Techniques Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates different ways of handling errors in LabVIEW
Description
The first method demonstrated manually creates an error cluster. The second method creates an error cluster when only given an error code. The third method is the standard error passing that many VIs implement. Finally, merging multiple errors is demonstrated. This example does not nearly cover all the different ways to handle errors.  If you have other ideas that would be helpful, feel free to edit the VI and the VI Snippet and add them to this document.
Requirements
LabVIEW 2012 or compatible
  1. Take the error out of a VI and use a Case Structure to determine if you want to manually create an error. If so, use a Bundle by Name function and enter the values for the status, code and source.
  2. If a DLL returns an error code- in order to create an error cluster from it, use the Error Cluster from Error Code VI. Input the appropriate error message.
  3. Standard VIs will pass out an error cluster
  4. Use Merge Errors to combine multiple error wires into one. Merge Errors will return the first error found. If there are no errors, it will return the first warning found. If there are no warnings, no error is returned.
VI Block DiagramError Handling Techniques LV2012 NI Verified BD.pngError Handling Techniques LV2012 NI Verified BD.png
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
Petru_Tarabuta
Active Participant Active Participant
Active Participant
on
A useful summary of a variety of techniques for handling or manipulating LabVIEW errors is found at: NI Community: LabVIEW Error Responses.pdf.
