-This VIs reads and writes data to database table true Labview cluster.
The benefit of this code is that you only update/create cluster and database table and you have a full functional code for read/write your data to database.
The DB_Read use the cluster to define the table and column in your database and pass the result into the array returned data depending on your SQL query.
The DB_Write writes the data in your cluster do the database and read back its record key.
Clever solution!
I have found this error Error -2147467259 occurred at NI_Database_API.lvlib:Cmd Execute.vi->NI_Database_API.lvlib:DB Tools Insert Data.vi->Untitled 1
please i need help
