Example Code
Easy HTTP Client VIs
Code and Documents
Introduction:
I found myself continually performing the same operations in conjunction with the HTTP Client VIs in LabVIEW.  I was always parsing the header, checking for 500 errors, and the like.  Eventually I wised up and created these VIs that do all of that for you!
Steps to Complete:
The VIs are all in a single VI Package.  The new pallete will include new versions of the HTTP Client VIs as well as a subpallete that contains the VIs native to LabVIEW.  The pallete is also located on the top level of the functions pallete; I found the native location in LabVIEW very inconvenient.
Enjoy!
Additional Notes:
The Easy HTTP Client VIs can be differentiated from the native LabVIEW VIs by the wrench in the upper right hand corner of the VI icon.
Applications Engineer
Comments
Peter-daq.io
on
Hey everyone,
does anyone still maintain this project? We found an error on other system locales (decimal point is a comma, for instance): "Interpret header.vi" will throw an error for the http version. Fix: force the locale to a decimal "point" by adding '%.;' to the "Scan from String" parameter.
Other than that, great package, very useful and handy!
CLD | Alliance Partner | Web data storage and visualization | daq.io
alekennedy
on
When I send a POST Request with content-type application/json,  I get a Response Code 100 and the library show me an error code 800100. Can anybody help me?
brentjustice
on
I was inspired by this code, but I kept bumping into issues with it, so I created my own branch.
I improved a few things and added debug log hooks.
If you are interested::
https://www.vipm.io/package/blue_origin_lib_blue_easy_http_client_opensource/
Contributors
