From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Example Code
Dynamically Call Multiple SubVIs From a Queue
Code and Documents
This example shows how to use a producer\consumer design pattern with a queue to dynamically call multiple subVIs. The subVIs are called and then run independently of Main.vi. This means that they are running but Main.vi does not wait for them to finish executing before continuing (they are non-modal).  This is useful if you want to create a scalable solution for having multiple popup windows while still allowing the main part of the program to run.
The Main VI has two buttons that will call two separate subVIs.  The first subVI shows the amount of time that has elapsed since it was called.  The second subVI generates and displays a random number.
In this example, user events add subvis to a queue that will be called in the consumer loop.  In other applications, any type of event (i.e. programatic event) can add a subVI to the queue.
Main VI:
SubVI:
Comments
JUSTBEGINE
on
hey can u share the procedure please how to do the above task?
Contributors
