Example Code
Dual Monitor Quick Drop Plugin For Window Snapping in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example adds functionality in LabVIEW to tile your front panel and block diagram to seperate screens.
Description
Makes use of LabVIEW properties and windows dll files to maximise the front panel on one monitor, and the block diagram on the other. For those who would like the functionality of CTRL + T to expand to multiple monitor support.
This plugin was built based on the plugin template, QuickDrop Plugin Template.vit that can be found in C:\Program Files (x86)\National Instruments\LabVIEW 20XX\resource\dialog\QuickDrop.
Requirements
  • LabVIEW 2012 (or compatible)
  1. The VI and included library can be extracted into your quick drop folder (typically found at C:\Program Files (x86)\National Instruments\LabVIEW 20XX\resource\dialog\QuickDrop\plugins).
  2. Open a blank VI and test the functionality, you should be able to open quick drop using CTRL + SPACE, and then whilst the quick drop window is open, use CTRL + T to tile to multiple monitors
VI Block Diagram
Matt H
Applications Engineer
National Instruments UK
Comments
dagelet_p
NI Employee (retired)
on
Very nice plugin!
Use it all day.
Thank you
Hooovahh
Proven Zealot Proven Zealot
Proven Zealot
on
Isn't the CTRL+T used for the Move Terminal Labels which is installed with LabVIEW?  I would suggest using a different shortcut that doesn't interfere with base LabVIEW functionality.
EDIT: Oh and you can get the HWND of the front panel or block diagram using property nodes in LabVIEW I think the Property is called Native Window
