Overview
This example adds functionality in LabVIEW to tile your front panel and block diagram to seperate screens.
Description
Makes use of LabVIEW properties and windows dll files to maximise the front panel on one monitor, and the block diagram on the other. For those who would like the functionality of CTRL + T to expand to multiple monitor support.
This plugin was built based on the plugin template, QuickDrop Plugin Template.vit that can be found in C:\Program Files (x86)\National Instruments\LabVIEW 20XX\resource\dialog\QuickDrop.
Requirements
VI Block Diagram
Isn't the CTRL+T used for the Move Terminal Labels which is installed with LabVIEW? I would suggest using a different shortcut that doesn't interfere with base LabVIEW functionality.
EDIT: Oh and you can get the HWND of the front panel or block diagram using property nodes in LabVIEW I think the Property is called Native Window
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
