Example Code
Display Point Cloud in 3D Picture Control
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Code that shows how to load a 3D point cloud data into a 3D picture control in LabVIEW.
Description
Point cloud data is typically generated from scanning operations such as robotic sensors and laser scanners. This code takes advantage of the meshes available in the 3D picture control. If you generate individual objects for each point, then you soon run out of computing resources! Meshes are much more efficient and the example uses a 1,000,000 point cloud without any issue.
Requirements
LabVIEW 2012 (or compatible)
1. Select if you would like to load from file or generate a random object.
2. Run the VI.
3. Use the Camera Controller to adjust the way the mouse moves the 3D object.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Comments
anfedres86
on
Where I can find the file that did you use to see the point cloud?
"Everything that has a beginning has an end"
anfedres86
on
anfedres86
on
James_McN
Active Participant Active Participant
on
I got the data from http://www.pointcloudmodeling.com/samples.htm as a free sample
James Mc
James_McN
on
James Mc
londonew
on
Please, could you convert the file to LV 8.2? I would appreciate all help at this time. Thanks.
londonew
on
Thanks JamesMcN but I can't run the .VI since there is a missing method in the code. The problem is between step # 2 and # 3 where it is displaced a SceneObject --> Set Drawable --> Drawable. I tried to solve this connecting the ScenMesh (at step # 2) with SceneObject --> Set Geometry --> Geometry (at step #3) and its runs but doesn't shown anything at the screen. I made sure that data was passing to the mesh and this is not the problem. Maybe the sceneObject is not chosen properly or needed a light to make visible the points at the scene?
ritayuan
on
It is what i am looking for. thanks
