Display Image As Boolean 2D Array With NI Vision Development Module
製品と環境
このセクションは、サンプルの作成に使用された製品およびOSを反映します。
以下に示された製品を含め、NIのソフトウェアをダウンロードするには、ni.com/downloadsをご覧ください。
    ソフトウェア
  • Vision Development Module
  • LabVIEW
コードとドキュメント
添付
すべてをダウンロード
Overview
This example demonstrates how to display an image as boolean 2D array.
Description
I wrote this example for a bit of fun to show how images can be loaded into LabVIEW and pixel information taken out.
You run the VI and select an image to be loaded in and turned into a boolean array (Do not load an image too big or it might crash as every pixel of the image is represented by a boolean).
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open and run the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Owen.S
Applications Engineer
NIコミュニティのサンプルコード交換のサンプルコードは、MIT Licenseによりライセンス供与されています。
コメント
ssingh1
Nice one.
Shazil
Hey,
This is a great example... But how can you import an image onto a fixed sized grid. For example an 8x8 boolean array.
I tried editing your example, but basically I cannot alter the pixels to fit the smaller grid...
Shaz
